TV mounting location in Launch 17SB
Re: TV mounting location in Launch 17SB
Quick update. I finally had time to get around to this project and found the mounting location. I will be placing some plywood on the interior of the pantry just to make the mounting a bit stronger. The bracket I have has a pretty high weight limit (much higher than I would ever need, so I am wondering what the recommended max weight of the TV should be. I am looking at 19" and 24" TVs weighing between 4.2 and 5.5 lbs. What should the max weight be when mounting to the mfg. location on the pantry with a piece of plywood inside the cabinet?
No issues at all, we love her. She tows well behind our Honda Ridgeline and has been a wonderful camper. We especially like the powered awning, on our old pop-up we hardly ever used the awning since it was so difficult to setup and stow. The only real change I am going to make is to add a power tongue jack. With the WDH, the manual/crank jack gets old.
Hey outwrdbound,outwrdbound wrote:Hello,
We purchased a 2016 Launch 17SB earlier this year and would like to mount an LCD TV. Can anyone help me with the location of the mount? In searching the topic, I have seen other Launch hybrids with a sticker that appears to indicate the mounting location, however, ours has/had no such sticker. We purchased it new, so I presume the dealer removed it prior to delivery. Thanks for the help!
Cheers.
How you liking the 17sb,were really intrested in one ,any issues wuth her?
- oldenuftoknowbetter
Contact Starcraft and ask them. Starcraftrv.com (you'll need your registration #) While you are at it, request the framing drawings. They may come in handy down the road.
Hello,
Cheers.
Cheers.
