keep blowing #30 fuse on hitch
Discussion for all discontinued or other model RVs. Don't own a Starcraft? That's ok, we'll let you sit around the fire too.
realmsailing
Re: keep blowing #30 fuse on hitch
Post by realmsailing » October 7th, 2018, 12:26 pm
cattzap wrote:
July 25th, 2018, 12:16 pm
Mark the leg of the jack with a red tape wrap or something so you know to stop early. Also, you can replace the fuse with a resetable breaker so if it happens again it's easy to get it going again.
https://www.delcity.net/store/Thermal-P ... 3GEALw_wcB
Thanks for the link.
matthewcreath
Post by matthewcreath » August 12th, 2018, 8:42 pm
yes that is the one for us too, and does the exact same thing.
Matthew
cattzap
Post by cattzap » July 25th, 2018, 12:16 pm
Post by pawpaw » July 4th, 2018, 12:20 pm
If you hold the switch until the jack hits the upper or lower limits the fuse will blow. Try releasing the switch a little before the limits are reached.
Post by uct » July 3rd, 2018, 11:16 pm
Yes. I cut the wires and soldered in a new holder has not blown since. I tried cleaning the old one first helped for a little while. Also I am always either plugged in at the campsite or plugged in to my truck before I use the electric jack
matthewcreath
Post by matthewcreath » July 3rd, 2018, 4:01 pm
really? so literally just the square housing part? and that fixed it?
Post by uct » June 28th, 2018, 8:46 pm
Mine did the same. I replaced the fuse holder
matthewcreath
Post by matthewcreath » June 28th, 2018, 7:41 pm
hi. we bought a 2017 Starcraft Satellite and we keep blowing the fuse. it is the fuse that is in the wiring on the hitch area by the battery. when it blows, we have no power to the electric hitch or the unit itself. we replace, and everything works perfect. it blows at least once every trip. Any ideas?
